Customizer
I am getting a bit frustrated with the customizer.
I created a new lay-out and a new style (based on copy of default) using the customizer and changed the title and body font and the main menu color.
-1- The title font is set to 'Dosis', and although it is set correctly in the css file is is often not used on the screen. Instead the 'system default' font is used. Only when I change it to another font and then back to Dosis it is used. Unitl I make some other change in customizer.
-2- I created some new pages and they just doon't use the set style, they just use the default style. This is true both for new pages as well as for pages which are copies from existing pages in the demo data. No idea what is happening. Menu have the same Template style setting are same as with pages that have he correct style. Checking with Firebug shows that default css is loaded, not the one that belongs to the set style. Style has been assigned to all pages.
Checking the database: in table _menu the template_syle_id is the same as with the menu items that are correct.
Cache in Joomla is switched off, in browser has been emptied (100+ times by now).
No clue how to fix this issue
by fgbnl
see
new.2bvisible.nl/
for the site
by fgbnl
Solved the issue (I think). At he bottom of the lay-out tab you need to mark the menu items that should use the style. I had not done that, assuming that was done through the menu assignment tab. Still would like to know what is controlled through the menu assignment setings and what through the menu settings at the bottom of the layout page.
by fgbnl
Video:How to setup a layout
www.joomlaplates.com/support/documentati...profile-to-menu-item
And please make sure that you have setup the template as default and it is assigned to all menu items
Last Edit:8 years 4 days ago
Last edit: 8 years 4 days ago by joomlaplates.
I have a setup which is as shown in the video.
3 issues remain:
- what is the 'menu assignment' for?
- I keep losing settings font settings from the customizer. If a check the less file for my custom theme the @import font rule is missing every time I do not explicitely set the font.
3 issues remain:
by fgbnl
1.) Delete all layout which are not needed
2.) Compile LESS
3.) Clean your Joomla and Browser Cache
2.) Compile LESS
