[SOLVED] how to modify the Home Headerbar Slideshow
  • zarzor
  • zarzor's Avatar Offline Topic Author
how to modify the Home Headerbar Slideshow was created by zarzor
Posted 6 years 2 months ago #21519
Hi There,
can you please advise which file to edit to modify the Home Headerbar Slideshow height, I know the location for the width but I can't see how to do the height ll to say 500-600Px.
https://mysite/templates/jp-power/roksprocket/layouts/features/themes/slideshow/slideshow.css line 14 shows only width:100%
Thanks in advance
by zarzor
Replied by joomlaplates on topic how to modify the Home Headerbar Slideshow
Posted 6 years 2 months ago #21520
HI there,
you cant change the height of the image, otherwsie you will loose the responsive mobile ready view
If you want to change the height of the module please change the ratio from your image
  • zarzor
Replied by zarzor on topic how to modify the Home Headerbar Slideshow
Posted 6 years 2 months ago #21523
Thank you for the prompt reply, the module height is too large, once you open the page the image almost cover half of the screen, the default image size that was loaded with the demo files is 2292 X 882 px, I have tried to use smaller image like 2292 X 450 px, and it still shows the same size as the original image.
I know to have responsive template it has to adjust horizontally with the max width of the device displayed with, however the vertical ratio should have limit because it cover half the screen.
thank you again for the help
by zarzor
  • zarzor
Posted 6 years 2 months ago #21524
can you please elaborate, what do you mean by " If you want to change the height of the module please change the ratio from your image"
I did change the image size many time it is still showing the same way in the page, I need to modify the module height to be for instance 450px how can you do this?
thank you again for your help
Last Edit:6 years 2 months ago by zarzor
Last edit: 6 years 2 months ago by zarzor.
Posted 6 years 2 months ago #21525
Live Url please.
And then I can give you a css code for the max height of the mdoule
  • zarzor
Posted 6 years 2 months ago #21526
the site is not live I'm testing the template
by zarzor
