Different Colour for module position ?
- arno001
- Topic Author
- Visitor
Hi Guys
Another maybe totally stupid question. Can you change the color for specific module positions for example Position Bottom D? - i want i light grey. My body background colour is black.
Cheers
Arno
Cheers
Arno
by arno001
Replied by joomlaplates on topic Different Colour for module position ?
Posted 10 years 9 months ago #5453
You can change the module background very easy.
Goto the template > customizer > Advanced > Content and Module > Box Primary Background
And set your color
After that you have to asign the bottom-a or bottom-b module to the assign "primary" style
And set your color
Attachment modulecolor.jpg not found
Attachment module-color-2.jpg not found
- arno001
- Topic Author
- Visitor
Replied by arno001 on topic Different Colour for module position ?
Posted 10 years 9 months ago #5454
Hi
Ok that was easy - how about i want to change the entire module position over the entire width of my template ?
Example : Top A is a light grey
Top B is a darker grey
Is like horizontal dividers just for the entire sector.!? Same length as the footer..
Plus i can't get the horizontal dividers to work i always get vertical dividers only
Cheers
Arno
Cheers
Arno
by arno001
Posted 10 years 9 months ago #5455
If you want to have another color for other modules you have to setup the background color:
Cusomizer > Box Secondary > Setup your color
And now assign the module to the "box-secondary" style.
Vertical divider are not supported!
