SlitSlider does not display any animation
- corrilan
- Topic Author
SlitSlider does not display any animation was created by corrilan
Posted 11 years 8 months ago #5543
Hello
I have various images (banners) within SlitSlider module. I have text configured to display using an animation but the animations are not working. The text is displayed as soon as the image banner appears. Increasing the log level displays the following page load errors:
Notice: Undefined index: animation in /var/www/customersites/www.corrilan.com/templates/jp-xtra/layouts/widget.php on line 99
Notice: Undefined variable: animation in /var/www/customersites/www.corrilan.com/templates/jp-xtra/layouts/widget.php on line 101
Strict Standards: Only variables should be assigned by reference in /var/www/customersites/www.corrilan.com/modules/mod_slitslider/mod_slitslider.php on line 16
Strict Standards: Non-static method JVersion::isCompatible() should not be called statically in /var/www/customersites/www.corrilan.com/modules/mod_slitslider/tmpl/default.php on line 26
Regards
Jason
Regards
Jason
by corrilan
Replied by joomlaplates on topic SlitSlider does not display any animation
Posted 11 years 8 months ago #5544
these are just "noticed" and no errors and has nothing todo with your slitslider.
Live Url to check your site
