SlitSlider does not display properly on mobile
SlitSlider does not display properly on mobile was created by buskerud
Posted 11 years 6 months ago #5755
I'm working with JP Extrea and slitslider, when viewing on mobile the slides shows only a tiny part of the image.
It's the same on the demo as well, can this be fixed?
www.lyspunkt1.no/ns/
Thank you
Bjorn
Thank you
Bjorn
by buskerud
Replied by joomlaplates on topic SlitSlider does not display properly on mobile
Posted 11 years 6 months ago #5756
The slider should not have the full height in mobile view, if you dont like it you have to delete the syntax below from slitslider > line 67:
http://www..../modules/mod_slitslider/assets/css/slitslider.css
.jpslitslider img {
max-width: none !important;
Replied by buskerud on topic SlitSlider does not display properly on mobile
Posted 11 years 6 months ago #5757
I will try that.
Thank you
Bj
Thank you
Bj
by buskerud
Replied by enserk on topic SlitSlider does not display properly on mobile
Posted 11 years 5 months ago #5840
Is it possible to display the text in the slit slider in the mobile version?
If the templates swaps to the mobile version the text disappears?
by enserk
Posted 11 years 5 months ago #5841
The text is to big for the mobile view.
