Access problem styles customizer
Unable to access the menu
I have the following error message:
"Retrieving styles data failed!"
by uechi
Replied by joomlaplates on topic Access problem styles customizer
Posted 10 years 3 months ago #6116
please more details. Which extensions are installed?
>> If "joomsocial" is installed please disable the joomsocial updater.
>> If Gantry was installed before, please remove all gantry related plugins and extensions
And please make sure that all files and template folder is writable.
/administrator/templates/system - 777
templates/jp-{your template} -777
www/templates/jp-{your template}/less/style.less -777
Great, problem solved. This came from Gantry. I uninstalled everything and now it works.
Thank you
Thank you
by uechi
