[SOLVED] Module Position
- quasarsi
- Topic Author
Please could help me. Thank You.
If you insert the code, please disable the Joomla editor, otherwise the editor will remove the vide iframe after saving.
<iframe src="//player.vimeo.com/video/28457282?title=0&byline=0&color=c9ff23" max-width="100%" width="100%" height="189" frameborder="0" webkitallowfullscreen mozallowfullscreen allowfullscreen></iframe>
<div class="uk-width-1-1 uk-panel-box-blue">
<h3>Template Features</h3>
<p><i class="uk-icon-check"></i> Responsive Layout build with Warp* 7</p>
<p><i class="uk-icon-check"></i> 300 Google Fonts & 250 Icons</p>
<p><i class="uk-icon-check"></i> Slideshow/Mosaic/Tabs Module included</p>
<p><i class="uk-icon-check"></i> Unlimited Colors with easy Customizing</p>
</div>
- quasarsi
- Topic Author
a greeting
- quasarsi
- Topic Author
