Mobile menu not possible click in active section!
  • 3dmark
  • Topic Author
Mobile menu not possible click in active section! was created by 3dmark
Posted 11 years 1 month ago #6762
Why in mobile menu not possible click, if I am in the section?
for example, if I go to the section MODULE VARIATIONS I can not push it on the menu!
You joomlaplates:
The template you asked about is from Yootheme and not from us!
Please ask there
yootheme.com/support
I do not understand you!
I have bought the template Galeria, any questions and problems, and you are sending me to YOOTHEME!
Please explain why?
by 3dmark
Replied by joomlaplates on topic Mobile menu not possible click in active section!
Posted 11 years 1 month ago #6763
1.) I have sent you to Yoothemes because you were talking about the "EAT" theme ( see your attached screenshot). And the eat theme is from Yootheme
2.) And I told you that the Galeria theme has no "offcanvas" menu position and no "offcanvas" mobile menu.
And now back to your problem:
I cant see any problems with the mobile menu, see image attached from Iphone.
I could click the menu item "Module Variations"
Attachment IMG_0971.png not found
  • 3dmark
  • Topic Author
Replied by 3dmark on topic Mobile menu not possible click in active section!
Posted 11 years 1 month ago #6764
I told you about EAT wrote about konvas how about an example!
If I click on the menu, the page is not updated! ie I can not get into the section, if i entered in the material! The chosen menu item is not updated !!! when I choose the section in menu, it must be reloaded... example: cat1>cat2>mat how i can load in mobile menu CAT2 cat1>cat2> ??
Last Edit:11 years 1 month ago by 3dmark
Last edit: 11 years 1 month ago by 3dmark.
Posted 11 years 1 month ago #6769
Hi there, thanks for the video.
Which Browser, which System, which phone do you use?
We have tested on Iphone and Samsung and it works. We can not test it on all mobile devices, maybe a system issue from your phone!
If nothing helps you can get a refund, no problem!
Last Edit:11 years 1 month ago by joomlaplates
Last edit: 11 years 1 month ago by joomlaplates.
  • 3dmark
  • Topic Author
Posted 11 years 1 month ago #6772
It not matters. I think you not understand what I want.
Simply say I want that "select" element fire reload page onclick not onchange.
by 3dmark
Posted 11 years 1 month ago #6776
I have tested it on Iphone and the site is reloading if I select a menu item.
Sorry I cant undedtand the problem, coz I can not see the issue
