[SOLVED] Width Article Backgroud
Replied by joomlaplates on topic Width Article Backgroud
Posted 10 years 1 month ago #7119
If you have insert an image for the background, you have to disable the image overlay, see image attached.
Attachment overlay.jpg not found
And now create a new custom html module and insert a blank div with a height and publish this module at position "slidetop"
See image below
Attachment custom.jpg not found
Replied by FernandoXD on topic Width Article Backgroud
Posted 10 years 1 month ago #7120
Thanks, yes I know that... but my question is about is can I do something like the sections on bike's template
Attachment example.png not found
joomlaplates wrote: If you have insert an image for the background, you have to disable the image overlay, see image attached.
See image below
Posted 10 years 1 month ago #7121
If you follow my description as shown above you will get the same effect.
But its not possible to set a background for each module position at the X2 Template.
The following user(s) said Thank You: FernandoXD
Replied by FernandoXD on topic [SOLVED] Width Article Backgroud
Posted 10 years 1 month ago #7122
Posted 10 years 1 month ago #7123
Thanks =)
  • ingo24
  • Visitor
  • Visitor
Replied by ingo24 on topic Width Article Backgroud
Posted 9 years 10 months ago #8182
Very good explanation. Thanks!
I was thinking maybe there is an extension, a module that would work to set a background image into the position of the module.
Even better if i could choose a picture instead of a color... for the whole background in my module area.
Thanks again
by ingo24
