[SOLVED] Problem with RokSprocket
Problem with RokSprocket was created by plachillos
Posted 11 years 2 weeks ago #7306
I installed the Galeria Template -then the Roksprocket extension. When I create a new module -fill in title and so on i get the following message when I try to save or press continue. Very frustrating.
Error while saving
Invalid JSON data Uncaught Exception: Table 'demoillo.olc_roksprocket_items' doesn't exist SQL=SHOW FULL COLUMNS FROM `olc_roksprocket_items` [1146] File: /mnt/data/vhosts/casite-652430.cloudaccess.net/httpdocs/libraries/joomla/database/driver/mysqli.php Line: 610
Thanks,
Paul
Last Edit:11 years 2 weeks ago by plachillos
Last edit: 11 years 2 weeks ago by plachillos.
Replied by joomlaplates on topic Problem with RokSprocket
Posted 11 years 2 weeks ago #7308
seems to be a problem with your installed extension and sql database
1.) Goto extension manager > manage > search for "rok"
2.) Mark all "rok" based extensions and uninstall this ones
3.) Now install the extension again, it should work
Replied by plachillos on topic Problem with RokSprocket
Posted 11 years 2 weeks ago #7310
Uninstall all of these?
I'm not very experienced at this so your patience is greatly appreciated.
Cheers!
Posted 11 years 2 weeks ago #7312
Yes uninstall all of these ones
Posted 11 years 2 weeks ago #7316
That seems to have done the trick. Thank you for the great support!
Cheers,
Paul
Replied by plachillos on topic [SOLVED] Problem with RokSprocket
Posted 11 years 2 weeks ago #7317
