[SOLVED] background behind triangle
  • GoossensTP
  • Topic Author
  • Visitor
  • Visitor
background behind triangle was created by GoossensTP
Posted 10 years 1 week ago #7510
dear Forum,
Ik would like to change the picture at the background of the triangle. If a picture is uploaded in " options" at the triangle (module>logo center big) it is visualized but it won't stretch in the right way. It's to small.
Where can I change the settings to make things fit properly?
Thank you.
by GoossensTP
Replied by joomlaplates on topic background behind triangle
Posted 10 years 1 week ago #7512
you should extract your logo without the background image, triangle only in png24 transparent
1.) Use the triangle at the logo module position
2.) Upload your image and point your image at the template config > Logo Background
Attachment triangle_2015-04-10.jpg not found
Attachment logo-bg.jpg not found
Last Edit:10 years 1 week ago by joomlaplates
Last edit: 10 years 1 week ago by joomlaplates.
  • GoossensTP
  • Topic Author
  • Visitor
  • Visitor
Replied by GoossensTP on topic background behind triangle
Posted 10 years 1 week ago #7513
Thank you for your reply.
how do I get into the warp menu? I haven't used that yet.
by GoossensTP
Posted 10 years 1 week ago #7516
Extensions > Template > jp-ultimate > Options
The following user(s) said Thank You: GoossensTP
  • GoossensTP
  • Topic Author
  • Visitor
  • Visitor
Replied by GoossensTP on topic [SOLVED] background behind triangle
Posted 10 years 1 week ago #7519
by GoossensTP
