QuickStart doesn't work
I am trying to install the quickstart 3.x, but the creation of the database doesn't finishing.
I even tried to replace the engine=InnoDB to engine=MyIsam to both files, it does not work either...
Can anybody try it, and tell me if it working anymore or not?
Thanks in Advance!
Thanks in Advance!
by lakis21
Please make sure that your host is Joomla 3.4 ready and compatible.
docs.joomla.org/Technical_requirements
Yes all the other templates quickstart like hi-fi is working fine.
Joomla 3.4.1 working fine in the server. Something is wrong with this specific quickstart.
Thank you
Thank you
by lakis21
