[SOLVED] Widgetkit and JP Xtra do not work together
  • iqmessenger
  • Topic Author
  • Visitor
  • Visitor
Widgetkit and JP Xtra do not work together was created by iqmessenger
Posted 9 years 11 months ago #7812
When I install Widgetkit my website totally disappears.
Joomla is up to date, all my extensions are up to date and I'm using the newest version of Widgetkit.
What can be the problem?
I'm experiencing the same trouble when installing other extensions.
by iqmessenger
Replied by joomlaplates on topic Widgetkit and JP Xtra do not work together
Posted 9 years 11 months ago #7813
which Widgetkit did you installed?
Please do not install the widgetkit 2 > See image attached
Attachment widgetkit_2015-04-29.jpg not found
  • iqmessenger
  • Topic Author
  • Visitor
  • Visitor
Replied by iqmessenger on topic Widgetkit and JP Xtra do not work together
Posted 9 years 11 months ago #7814
Initially I installed Widgetkit 2. That version did not work.
I then installed Widgetkit Lite (Free), but that version does not work too.
by iqmessenger
Posted 9 years 11 months ago #7816
You need to uninstall ALL widgetkit 2 files, before you install the widgetkit lite!
See image attached.
Attachment widgetkit_2015-04-29-2.jpg not found
Why you didnt installed our quickstart package, here is all included?
  • iqmessenger
  • Topic Author
  • Visitor
  • Visitor
Posted 9 years 11 months ago #7818
I removed all Widgetkit 2 files and I emptied the cache. Now everything works fine.
I did not know there was a quick start package available as my colleague has installed the template.
Thanks for your help.
by iqmessenger
Replied by joomlaplates on topic [SOLVED] Widgetkit and JP Xtra do not work together
Posted 9 years 11 months ago #7822
