article exists but can not be displayed
Replied by joomlaplates on topic article exists but can not be displayed
Posted 10 years 10 months ago #8277
It depends on your langauge settings.
Please make sure that your article and menu item are assigned to the right language.
Video how to:
  • giuse88
  • Topic Author
Replied by giuse88 on topic article exists but can not be displayed
Posted 10 years 10 months ago #8279
yes I now.
The language setting is correct.
can you check please?
by giuse88
  • giuse88
  • Topic Author
Posted 10 years 10 months ago #8281
This voice of menu:
link
should invoke article "test444" with this text:
Prprrrrrrrrrrrrrrrrrrrrrrrr
fdgsdfgsdfgdfgsdfgsdfg
Instead the page you see is empty ...
Some menu items work properly not. Please check . I urgent need to solve the problem
by giuse88
Posted 10 years 10 months ago #8283
As I told you above its a language problem.
Please make sure that your article is assigned to the right language:
Menu item = en
Article = en
  • giuse88
  • Topic Author
Posted 10 years 10 months ago #8293
As I told you I am assigned to the correct language . Article Italian , Italian menu .
Please check with the data that I sent as administrator
by giuse88
Posted 10 years 10 months ago #8299
You have "hide" the system output for the default style, I have enabled the system output and it works.
Attachment hide.jpg not found
If you want to hide the system output, you have to:
1.) create a new style
2.) Disbale the system output
3.) Assign the new created style to the menu item
Last Edit:10 years 10 months ago by joomlaplates
Last edit: 10 years 10 months ago by joomlaplates.
