[SOLVED] Problem with module edit in frontend
I have a problem with the template... after a migration.
I put a new one compatible with Joomla 3.
When I want to edit a module in frontend, I have this popup :
Calendar.setup:
Nothing to setup (no fields found). Please check your code
When I put an other template. There is no problem.
Any help please
Thanks
Calendar.setup:
Any help please
Thanks
by groug
Replied by joomlaplates on topic Problem with module edit in frontend
Posted 10 years 9 months ago #8625
1.) Update to the latest Warp 7 framework version 7.3.6
2.) Delete your Browser and Joomla cache
3.) Make sure that Bootstrap is not disabled > Template Options > Bootstrap
Is the frontend module editing working with other modules?
I updates the latest version of warp and deleted the catch..
The editing module does not work with the other module
But there is always the same problem..
by groug
Posted 10 years 9 months ago #8627
Problem is solved.
System Output must be enabled for this site if you want to edit a module or content on frontpage
Last Edit:10 years 9 months ago
Last edit: 10 years 9 months ago by joomlaplates.
Replied by joomlaplates on topic [SOLVED] Problem with module edit in frontend
Posted 10 years 9 months ago #8635
