How to slide mobile menu from right to left?
- dizainr
- Topic Author
How to slide mobile menu from right to left? was created by dizainr
Posted 10 years 9 months ago #8746Attachment screenshot_mobile_fcs.png not found
Can you help me with the following issue: in the attachment you see an image of a mobile menu at the top right. Normaly in the JP-scene it is on the left. But because of the design I have to put it on the right. But now I also want to slide in the mobile menu form left to right instead of from left to right. You can see the url website en decrease your window or look at mobile.
How can I fix this?
Thanks!
Alwin
Last Edit:10 years 9 months ago
by dizainr
Last edit: 10 years 9 months ago by dizainr. Reason: no replies
Replied by joomlaplates on topic How to slide mobile menu from right to left?
Posted 10 years 9 months ago #8752
Try to add this syntax and put the code to your css/custom.css
We are committed to help you with any type of support query, however we can't provide extensive help in terms of customizations. In general customizations may look simple but you will require solid knowledge of web technologies and programming skills to do them or hire a professional who can do it for you..uk-offcanvas-bar {
right: 0;
