Transparent Module (Toolbar)
- CTSEngineering
I'm trying to make a module in the toolbar position (very top) transparent so that the background image is visible behind it, but not sure how to do it? Thanks in advance for the help.
The toolbar has a fixed background color at the php file:
>> layouts/theme.php
See image below.
To make the background transparent please use rgb instead of Hex code for the color:
www.css3.info/preview/rgba/
>> layouts/theme.php
See image below.
Attachment toolbar_2015-07-23.jpg not found
Last Edit:10 years 8 months ago
Last edit: 10 years 8 months ago by joomlaplates.
