[SOLVED] Problem edit or create the article from frontend
Problem edit or create the article from frontend was created by alepar
Posted 10 years 7 months ago #9363
Hi
I purchased JP Scene template for Joomla.
When I go to edit or create the article from frontend, the edit/create page is horrible and you cannot apply changes.
Is there a solution?
Thank you
Thank you
by alepar
Replied by joomlaplates on topic Problem edit or create the article from frontend
Posted 10 years 7 months ago #9364
please make sure that "bootstrap" is enabled.
>> Template > Options > Settings > Disable Bootstrap = NO
Attachment bootstrap.jpg not found
The following user(s) said Thank You: alepar
Replied by alepar on topic [SOLVED] Problem edit or create the article from frontend
Posted 10 years 7 months ago #9365
by alepar
