[SOLVED] Side blank after publishing RS Event pro Modules
- cbrandenburg
Topic Author
Side blank after publishing RS Event pro Modules was created by cbrandenburg
Posted 10 years 7 months ago #9375
After publishing a module in a moduleposition the complete site get blank and Empty.
Using latest version of RS Events pro from RSJoomla. asking parallel in rs joomla support to get a solution...
by cbrandenburg
Replied by joomlaplates on topic Side blank after publishing RS Event pro Modules
Posted 10 years 7 months ago #9377
It seems to be php script conflict.
Please check your server logfiles. I think it has nothing todo with the template!
- cbrandenburg
Topic Author
Replied by cbrandenburg on topic Side blank after publishing RS Event pro Modules
Posted 10 years 7 months ago #9383
It wasnt php. I used an older version of the modul. installed the newer version and voila -> its working.
Trotzdem danke.
Trotzdem danke.
by cbrandenburg
Replied by joomlaplates on topic [SOLVED] Side blank after publishing RS Event pro Modules
Posted 10 years 7 months ago #9385
