[SOLVED] Main Menu problems
  • the social effect
  • Topic Author
Main Menu problems was created by the social effect
Posted 10 years 7 months ago #9449
I have a problem with the main menu. One of the entries is "What we do" and is a text separator, because once you move your mouse on it, it turns in a drop down menu showing our 4 kinds of services. The problem is that the drop down menu is shown only in the Homepage, while if you try to open it from any other page (about, contacts, blog..) it's not shown. Moreover, in these cases if you click on the text separator it brings you back to the Homepage. There's no way I can fix it.
This is the link to the website: www.thesocialeffect.it
Does somebody know what could it be the problem?
Thank you so much.
Last Edit:10 years 7 months ago by the social effect
Last edit: 10 years 7 months ago by the social effect.
Replied by joomlaplates on topic Main Menu problems
Posted 10 years 7 months ago #9450
sorry but I can not see any of thee problems. See image attached.
Maybe you should clean your Joomla and Browser cache!
And please make sure that you have disabled all caching system plugins too
Attachment menu_2015-08-27.jpg not found
The following user(s) said Thank You: the social effect
  • the social effect
  • Topic Author
Replied by the social effect on topic [SOLVED] Main Menu problems
Posted 10 years 7 months ago #9460
