[SOLVED] does not work select template style
does not work select template style was created by gorod3922
Posted 10 years 5 months ago #9935
Hello! wanted to save changes to the template settings, but when saving I get a white screen, and the site resets to the "default" settings.
What to do? How to return the style "dark-menu"? http://davincitour.ru
Replied by joomlaplates on topic does not work select template style
Posted 10 years 5 months ago #9937
please update the warp theme framework
Replied by gorod3922 on topic does not work select template style
Posted 10 years 5 months ago #9943
Thank you! Did it! Works!
Replied by gorod3922 on topic [SOLVED] does not work select template style
Posted 10 years 5 months ago #9944
