Search box errors
Replied by alessandro.crespi on topic Search box errors
Posted 10 years 5 months ago #10378
In backend you will find a component to see FTP root and subdirectories.
Replied by joomlaplates on topic Search box errors
Posted 10 years 5 months ago #10379
You made a mistake.
You should override the folders.
But you have renamed the org folders and insert the update! Thats not working.
1.) Restore the org folder
2.) Backup the org folders to your harddrive
3.) Override the org folders with update folders
4.) Press compile less
If you want to backup the old folders, please zip the template and download the zip file to your harddisk.
Last Edit:10 years 5 months ago by joomlaplates
Last edit: 10 years 5 months ago by joomlaplates.
The following user(s) said Thank You: alessandro.crespi
Posted 10 years 5 months ago #10380
rtied it but same result.
Is there a way to download a "full updated" warp version?
I receive this error "compiling less"
The uploaded file exceeds the upload_max_filesize directive in php.ini.
Posted 10 years 5 months ago #10381
OK, I've fixe upload_max_filesize in PHP cpnfig and recompile LESS... but no results.
Search box in not working.
Posted 10 years 5 months ago #10382
It is an error in your Joomla file:
../components/com_search/views/search/view.html.php
Maybe something went wrong while updating to Joomla 3.4.5
You can copy the org Joomla files from here to your Joomla installation:
github.com/joomla/joomla-cms/tree/staging/components/com_search
Posted 10 years 5 months ago #10383
Just replaced all "com_search" dir (and subdir) and no effect.
