Few problems with the template
- adelgreeneyes
Hello, i am using this template on my website
centrehrw.com/
and i have few problems
1 - the slide is not responsive and i have no idea how to fix that
2 - when i try to do any customization from the template back end page for example add animation to a model the screen go blank when i save and the front end look missed up, check this link centrehrw.com/index.php/services before i add animation the 3 services which use TOP C position use to be next to each others, now they are under each other.
3 - the color of the template changed when i tried to do animation to module, i dont know exactly what the model animation have to do with template color.
4- even tho adding animation made all this problems the animation it self was not added
do this kinda wierd.
Note: do i need to install anything with this template to make it work better ? like fram work or something ?
do this kinda wierd.Note: do i need to install anything with this template to make it work better ? like fram work or something ?
Please re-download the template again, because we have removed the slitslider and using now the roksprocket slider which has a better
responsive view
responsive view
