[SOLVED] From submenu entry to corresponding mainmenu entry
From submenu entry to corresponding mainmenu entry was created by steimerweb
Posted 10 years 3 months ago #11177
when I'm on a site related to a submenu entry (e.g. Products -> Product 1) and I'm clicking on Products, I'm not able to get on the Products page again as the link is changing to .../products/product1#top instead of /products. Clicking on Products from a different site but the submenu entries works fine.
I'm using Joomla 3.4.8 Stable
Regards
Benjamin
Replied by joomlaplates on topic From submenu entry to corresponding mainmenu entry
Posted 10 years 3 months ago #11181
Live Url please and more details > Joomla version > warp and theme version, installed extensions
And please make sure, if you have 2 same menu items you are using for one of them > System > Menu Item Alias
Attachment menu-2-3.jpg not found
Replied by steimerweb on topic From submenu entry to corresponding mainmenu entry
Posted 10 years 3 months ago #11183
joomla3dev2.schlossberg-agrar.de
You can try reproducing it with "Theme Features" for example.
Installed from Quickstart, afterwards updated Joomla to 3.4.8 Stable ( 24-December-2015 19:30 GMT)
jp-snowflake 1.0.002
Warp Framework 7.3.16
Posted 10 years 3 months ago #11184
Hi there, yes youre right its a bug in Warp 7.3.16 and is not fixed right now!
yootheme.com/component/answers/question/92654#answer-274028
Here is the Warp 7.3.15, please upload all the files to your template folder and press "COMPILE LESS" from template options.
www.joomlaplates.com/warp/warp_wp_7_3_15.zip
Last Edit:10 years 3 months ago by joomlaplates
Last edit: 10 years 3 months ago by joomlaplates.
Posted 10 years 3 months ago #11188
Thank you! I rather did the described code replacement, but that fixed the problem.
Replied by steimerweb on topic [SOLVED] From submenu entry to corresponding mainmenu entry
Posted 10 years 3 months ago #11189
