[SOLVED] A few design questions
A few design questions was created by pacfood
Posted 10 years 2 months ago #11487
Hi
1: Can the menu path be removes from article pages? see attached.
2: The article page seems to have too much padding between top menu bar and content on the article pages. How can this be adjusted?
3: Can the snowflake dropdown menu be splt, like the HiFi Menu? See attached menu.jpg
Thanks
Rob
by pacfood
Replied by joomlaplates on topic A few design questions
Posted 10 years 2 months ago #11489
1.) The menu path is the breadcrumsbs module > disable it if you dont want to show the path
2.) The spacing is based on a "margin". You can remove this in > Customizer > Advanced > Grid margin
3.) Yes the menu can have max 4 rows > Template options > Menu > rows
The following user(s) said Thank You: pacfood
Replied by pacfood on topic [SOLVED] A few design questions
Posted 10 years 2 months ago #11498
by pacfood
