[SOLVED] problem between template and module
  • uechi
  • Thank you received: 1
problem between template and module was created by uechi
Posted 10 years 2 months ago #11900
My module does not work with this new template "interior V2" while works very well with my existing template "inspire"
My module is: Parallax Slider from ThemeXpert
My site : www.combatsdumonde.com/
What can I do ?
Best regards
by uechi
Replied by joomlaplates on topic problem between template and module
Posted 10 years 2 months ago #11902
your current url is based on "inspire" theme and I cant see any slider and the slider is not working.
And your html code have an error too, maybe that the issue.
Attachment error-2.jpg not found
We cannot guarantee the templates will function with all 3rd party components as there is currently no certification process for such components.
Maybe there is a scriptconflict between the slider and our theme scripts ( jquery)
  • uechi
Replied by uechi on topic problem between template and module
Posted 10 years 2 months ago #11905
Thank you for your answer.
What is the name of the file where I can find this error?
by uechi
Posted 10 years 2 months ago #11909
The wrong html code is in your joomla content article!
You dont have to search in any php file!
Last Edit:10 years 2 months ago by joomlaplates
Last edit: 10 years 2 months ago by joomlaplates.
  • uechi
Posted 10 years 2 months ago #11966
Everything is ok now
The problem is another module that I had installed.
The template works perfectly
thank you
by uechi
Replied by joomlaplates on topic [SOLVED] problem between template and module
Posted 10 years 2 months ago #11969
