[SOLVED] Problem video background
- vincent107
When you activate the video this is on top of the menu and change shape page.
This is what happens: screencast.com/t/knykqPOaWk
by vincent107
Live Url please.
And which extensions are installed !
Maybe you have installed a video plugin or extension?
- vincent107
This is the URL: pymehosting.cl/demo/imagen3d.cl/
Plugins are installed, the same as the Quickstart
by vincent107
there is a video player included and I dont know where it comes from. ( see image attached)
Please disable this widgetkit plugin and it should work > WidgetKit > Video = OFF
Attachment video-2.jpg not found
Last Edit:10 years 1 month ago
Last edit: 10 years 1 month ago by joomlaplates.
- vincent107
