[SOLVED] Problem with header padding
Problem with header padding was created by dillydally
Posted 10 years 5 months ago #13197
This is my third attempt to submit this to the forum and I truly do not understand why it keeps disappearing.
My question is how to change the padding space in the heading, I have used Firebug and adjusting the css but that didn't help at all as any changes I made did not adjust the space. You will see from the image that the logo and banner have quite a lot of space and I would like to minimise this, at least slightly to improve the top space. Can you provide me with what I need to change to affect this padding space.
Attachment surfnpaddle.png not found
Thanks
Replied by purzel on topic Problem with header padding
Posted 10 years 5 months ago #13199
1.) Which padding? Better screenshot with marked part of the padding
2.) Live Url please
by purzel
Replied by dillydally on topic Problem with header padding
Posted 10 years 5 months ago #13211
Attachment padding.jpg not found
The arrows show the padding area that I am referring to ... above and below the banner and logo.
Url = www.surfnpaddle.com
Replied by joomlaplates on topic Problem with header padding
Posted 10 years 5 months ago #13220
the gap is a margin. You can analyze it with a Browser, watch the video howto:
In your way you have to add this code below to your file: css/custom.css
.tm-headerbar {
margin-bottom: 0;
margin-top: 0;
Attachment headerbar-2-3.jpg not found
The following user(s) said Thank You: dillydally
Replied by dillydally on topic [SOLVED] Problem with header padding
Posted 10 years 5 months ago #13222
