Problems using Bike theme...
Problems using Bike theme... was created by dbhavant
Posted 9 years 11 months ago #13648
I seem to be having many issues with the Bike theme. The customizer appears to have limited effect especially on those pages containing Roksprocket elements. If I change the font in the customizer, each time I return it defaults back to the original font but displays a completely different one (looks like Times Roman).
When I change colour or font, the changes do not appear and everything reverts to a Times Roman type font. On the 'search' screen some changes appear such as menu, link colour and font size but not the font itself.
As it stands, the site now has a mixture of styles on different pages which is not what I want and I am all but ready to give up with this. I have tried changing permissions to ensure that the changes are saved correctly.
Any help whatsoever would be appreciated.
Thank you.
Replied by joomlaplates on topic Problems using Bike theme...
Posted 9 years 11 months ago #13649
1.) Template Details > Layouts > Remove all layouts you dont need.
2.) Make sure that your created style is set as default
Attachment layout-2-3-4.jpg not found
Replied by dbhavant on topic Problems using Bike theme...
Posted 9 years 11 months ago #13660
Thank you for your reply, unfortunately this seems to have little affect.
Following your instruction, I find that whatever I change the font to, it will always default back to 'Maven Pro'. Any changes made to font colour or link colour only take affect on regular pages (not Roksprocket modules).
On regular pages, although the font and link colour are changed successfully, the font looks like a serif font of some sort and is definitely not Maven Pro which it defaults to).
