[SOLVED] responsive menu not the same.
I have a strange problem with the responsive menu. I copied the main menu module and changed the position to offcanvas.
On the homepage I see the responsive menu sliding in but everything is in white, so you can't read the menu. When I open the menu from another page than the menu looks fine? (see screendumps)
The URL is www.verzoekjesapp.com/
I can't find what is casing this problem?
Thanx for the support!
Best regards,
Frits Strijbos
Attachment Verzoekjesapp.com-home.png not found
Attachment Verzoekjesapp.com-Hoewerkthet.png not found
Best regards,
Frits Strijbos
by frotjanus
Hi there, I have 2 Solutions
1.) Please update the template framework to the latest warp version
2.) Add this css code to your css/custom.css
body {overflow-x: visible !important}
I've updated the warp framework to the 7.3.22 Joomla version. But this didn't solve the problem. I then added the custom CSS code and this also didn't solve the problem.
Have you got any other suggestions?
Thanks!
Thanks!
by frotjanus
I cant see any custom css code in your site.
1.) Please disable your css compression plugin
2.) Leave it disabled until your site is ready for take off
3.) Clean the Joomla and Browser Cache
Yesssss, now it works fine
My mistake, I forgot the clean the cache after adding the custom css code.
Thanks very much for the fast support!
Have a nice weekend.
by frotjanus
Replied by joomlaplates on topic [SOLVED] responsive menu not the same.
Posted 9 years 10 months ago #13765
