Submenu not visible when anchor is visible
  • LabeL3
Submenu not visible when anchor is visible was created by LabeL3
Posted 9 years 10 months ago #13826
Hello Community,
I have a slight problem with anchors in an article:
The submenu in the sidebar is only visible as long as there is no anchor in the viewport of the page:
Page
For example: If you scroll down to "Highlights" and reload the page the menuitem "GL.evo" is collapsed and can't be opened either.
Is there a way to do a workaround?
Regards,
Patrick
by LabeL3
Replied by joomlaplates on topic Submenu not visible when anchor is visible
Posted 9 years 10 months ago #13829
the close and open function of the menu item is not working if youre using an "anchor" link.
The following user(s) said Thank You: LabeL3
  • LabeL3
Replied by LabeL3 on topic Submenu not visible when anchor is visible
Posted 9 years 10 months ago #13831
Thanks for the info!
Is there a workaround in some way? Anchors would be a nice thing to have.
Regards,
Patrick
by LabeL3
Posted 9 years 10 months ago #13834
Here is an instruction how to add a scroll to function to a menu item.
But I think its working only for main menu item and not in the accordion menu.
www.joomlaplates.com/forum/j3-snowflake/...anchor-in-page#13535
