Module Menu not shown in Template Options > Module
  • webmiep
  • webmiep's Avatar Offline Topic Author
Module Menu not shown in Template Options > Module was created by webmiep
Posted 8 years 5 months ago #14105
I do want to show a home icon in my main menu home menu-item.
I tried to add this And searched for the Template Options first in "Menu" but I only can select a menu. There are no options there.
Than I tried to do this in Template Options > Module > select your menu > Icon > select icon-home as you adviced in an other topic but the module menu is not shown there. Please let me know how to add the home icon on the home menu-item.
Thanks for your time.
Kind regards
Webmiep
by webmiep
Replied by joomlaplates on topic Module Menu not shown in Template Options > Module
Posted 8 years 5 months ago #14106
Please update the framework
After that you must see the icon section
Attachment icons-2-3-4-5-6.jpg not found
