[SOLVED] Top-A module padding reduce
- datacommerce
Topic Author
Hi. I would decrease the Top-A module vertical padding (see the attach).
How can I do that?
How can I do that?
by datacommerce
Template options > backgrounds > see image below
Attachment topa.jpg not found
Last Edit:9 years 8 months ago
Last edit: 9 years 8 months ago by joomlaplates.
The following user(s) said Thank You: datacommerce
- datacommerce
Topic Author
Replied by datacommerce on topic [SOLVED] Top-A module padding reduce
Posted 9 years 8 months ago #14651
by datacommerce
