The problem of saving items in Layouts of JP-ROOMS
  • bobyx
The problem of saving items in Layouts of JP-ROOMS was created by bobyx
Posted 9 years 8 months ago #14652
I designed a web by using JP-Rooms template;that is very unique and beautiful template.
But,I faced with a problem in designing of my projects at localhost and online
,both of them for a few times as the following;
I designed a bilingual web using JP-Rooms template .So,got a copy of that
and assign each of two jp-rooms to one of those languages.
Then,I entered to those above templates :Extensions > Templates >
jp-rooms - Default or jp-rooms - Default (2) >Layouts and select Yes for the
" Fixed Left Mainmenu " and changed the name of jp-rooms - Default (2) to
jp-rooms - Default (en) and click on save but it did not saved and all modules
that I placed on my "Home" page was displaced and my selected background
image and my movement menu was disappeared . And also,the place of my English
menu displaced with my other language.The background was changed into white
and my items menu was not seen but by placing cursor under word "Home".!!!
Would you please tell me what is the reason for the above mentioned problem?
And how can I solve it?
Thanks,
by bobyx
Replied by joomlaplates on topic The problem of saving items in Layouts of JP-ROOMS
Posted 9 years 8 months ago #14658
I think the reason is:
You can not copy the template within Joomla and use it for another language
If you want to have different styles for different menu items please go this way and use Layouts/styles
Video: www.joomlaplates.com/support/documentati...profile-to-menu-item
The following user(s) said Thank You: bobyx
  • bobyx
Replied by bobyx on topic The problem of saving items in Layouts of JP-ROOMS
Posted 9 years 8 months ago #14667
So,I designed wrongly from the first,for bilingual web site?
by bobyx
Posted 9 years 8 months ago #14672
Sorry, dont know what do you mean!!
