Applying Module Class Suffix
Hi. Is there a way to apply the Box Grey style to the system output and main menu?
When I add the "Box Grey" style to the to the menu via: EXTENSIONS->MODULES->MAIN MENU->ADVANCED->MODULE CLASS SUFFIX it fails to apply the style with the menu staying black.
Also, how do I add the Box Grey style to the main system output?
Last Edit:9 years 7 months ago
by VishalL
Last edit: 9 years 7 months ago by VishalL.
1.) The menu module color must be changed at Cutomizer and not with module class suffix.
>> Template options > Customizer > Advanced Mode > Panel > Primary Box
>> After that you can assign the "primary Box" to the module in Template options > Module
www.joomlaplates.com/support/documentati...the-customizer-warp7
2.) The system output must be changed in css code > css/custom.css
The following user(s) said Thank You: VishalL
Thanks.
Concerning the Menu style. I have this template set as a secondary template only to be applied to the websites store pages. When I try customize it I get the message that customization is not available for this template. Is this due to it not being the default style? (If I switch it back to the default style it allows customization as normal - Is this normal Warp7 behavior?)
by VishalL
you can not duplicate our theme within Joomla.
If you want to have different styles for different menu item you have to do this with "layouts"
How it works:
www.joomlaplates.com/support/documentati...profile-to-menu-item
How it works:
