[SOLVED] Problem TOP - breadecrumbs
Problem TOP - breadecrumbs was created by geertdirickx
Posted 9 years 6 months ago #15353
There is a white beam above breadcrumbs. The beam takes a part of the breadcrumbs.
Where does it wrong?
Replied by joomlaplates on topic Problem TOP - breadecrumbs
Posted 9 years 6 months ago #15354
Live url please!
What do you mean with "white beam"?
Replied by geertdirickx on topic Problem TOP - breadecrumbs
Posted 9 years 6 months ago #15355
a "stripe" above.
You can see it on www.lamp-aan.be/
Posted 9 years 6 months ago #15356
its a shadow and you see it, because it is transparent.
Please add this code to your css/custom.css to remove the shadow:
.tm-toolbar {
box-shadow: none;
Posted 9 years 6 months ago #15357
THX.
Before, there was a white part above the shadow. But I've change the bachgroundcolor of "section" in customiizzer styles.
After the adjustement, there was only a shadow.
Replied by geertdirickx on topic [SOLVED] Problem TOP - breadecrumbs
Posted 9 years 6 months ago #15462
