[SOLVED] Design / Layout problem
Adventures template is working great except i have an unsolved layout problem.
On following page I have a team description:
web333.login-46.hoststar.ch/Joomla_3.5.1.../index.php/ueber-uns
The text for Claudia Moser is not showing up. It is always the third article (i tried to switch them) and the title for Andreas Trächslin (the last one) is not showing up. Where can i change these settings? I have no clue, nothing worked out so far.
Thank you
Thank you
by Anita
Screenshot of the module config please.
And please make sure that you have a text in your Joomla article too, if you have Joomla for the provider.
Thank you for the reply.
Attached are the screen shots of the module. Is the quality good enough that you can read it?
Last Edit:9 years 5 months ago
by Anita
Last edit: 9 years 5 months ago by Anita.
I think there is something wrong here ( could not identify, image is to small) > red marked.
Please make sure that all description text is enabled!!
Attachment module-config-2.jpg not found
The following user(s) said Thank You: Anita
