Installation problem with quickstart
Installation problem with quickstart was created by gsmfastunlock
Posted 9 years 4 months ago #15833
Hi, I have serious problems with this quickstart template, I can not install it.
That the installation of the DB, the installation stops and come back to the part 3 of joomla! installation. I thought it was a database engine problem, but it is entirely correct (all in InnoDB), MySQL server and the installation sql files are InnoDB.
When the installation bar reaches half, crashes and comes back in the third installation of Joomla! (part3, Overview).
I have a very fast dedicated server (8 core and 32gb Ram) installed with over 30 other web pages with Joomla!.
max_execution_time in PHP.INI is in 600.
Going to open phpMyAdmin, we clearly see that the tables have been set up to "yvq_banner_clients".
Can you help me?
Attachment innodb-error.jpg not found
Thank you
Replied by joomlaplates on topic Installation problem with quickstart
Posted 9 years 4 months ago #15836
please take this settings for PHP
# example of recommended settings
php_value post_max_size 8M
php_value upload_max_filesize 8M
php_value max_execution_time 600
php_value memory_limit 128M
And please make sure that you are using the SQLi for Joomla installation.
Last Edit:9 years 4 months ago by joomlaplates
Last edit: 9 years 4 months ago by joomlaplates.
