problems with customization
problems with customization was created by carjum
Posted 8 years 2 months ago #16670
Hello I bought hifi template two or more years ago. I haven't try to customize until now. I do extensions --->templates---->stiles and select the default template THEN tab options --- and click settings under warp options ... with all that I click on customizer in the options at right... after this I select a custom stile but there is a message the current theme is not customizable... so my questions are: is there any restriction on customizing templates over certain period? or do I have to try clear cache, of follow any other tutorial?
kind regards
Attachment Screenshotfrom2017-02-1323-44-13.png not found
by carjum
Replied by joomlaplates on topic problems with customization
Posted 8 years 2 months ago #16674
Here is a trouble shooting guide:
yootheme.com/support/question/75099
The following user(s) said Thank You: carjum
Replied by carjum on topic problems with customization
Posted 8 years 2 months ago #16676
It was helpful, it solved the situation. thanks
by carjum
