Responsive Layout and Sidebars Problem
Is there any way to hide the menu but not the sidebars on tablets? It looks like that changing the values for sidebar-a or sidebar-b in the back-end (Templates: Edit Style | Layouts | Grid) does not affect the front-end at all.
by tvm
Replied by joomlaplates on topic Responsive Layout and Sidebars Problem
Posted 9 years 1 month ago #16692
You can play around with the grid at customizer > Advanced > Breakpoints
And the "medium" size should be the Table view!
Attachment breakpoints-2-3-4-5-6-7.jpg not found
Last Edit:9 years 1 month ago
Last edit: 9 years 1 month ago by joomlaplates.
The following user(s) said Thank You: tvm
Thanks a lot for the answer. I am not sure, but I think there is a bug in the CSS. When the html or body width is set to 1024 pixel (iPad landspace) the menu is above the content. In my opinion, the menu should be still on the left side. Also in the back-end (Extensions | Templates | Templates) the link to your website is wrong:
www.JoomlaPlates
by tvm
Last edit: 9 years 1 month ago by tvm.
Posted 9 years 1 month ago #16699
here are the part of the media queries when max-width is > medium
>> your template/less/theme.less > line 84
Copy and paste the code above to your css/custom.css and play with the width.
In this point I mean the max-widh, like this:
Attachment media-2-3.jpg not found
@media all and (max-width: 1024px) {
#jp-left { position: relative!important; width: 100%!important; height:auto }
#jp-left .inner { position: relative; margin: 0 0 20px 0; width: 100%; padding: 0; text-align: left; height: auto; float:none!important }
#jp-right { position: relative; width: 100%; margin: 0px auto!important; height: auto; padding-left:0!important }
