I need to resolve these issues, Please!
1. I need the image menu back in the popup menu like before in Editor - TinyMCE
-> I cannot edit image size in the Editor-TinyMCE directly. But I did it before I diabled it to use google map..
-> Now if I click the image on the Editor content box, I only see Link, Table, Cell, Row, Column menus on POPUP Menu.
2. If I edit some codes on the Toggle Editor and click Save button, screen suddenly switched to Visual editor mode and my codes disappeared.
The only thing I can do is that disable Editor - TinyMCE at the plugin menu and then back to product page and edit and save then, it is applied.
Please help me. HOw I can use the Editor Tiny MCE effectively?
Thank you very much.
by ohmani
Replied by joomlaplates on topic I need to resolve these issues, Please!
Posted 8 years 9 months ago #17563
please read this:
www.joomlaplates.com/support/documentati...content-was-cleansed
And here you can find all module content in html format:
demo.joomlaplates.com/jp_expert/docs/
>> Module Setup
please read this:
>> Module Setup
