Menu Module and Widget not visible on mobile
Menu Module and Widget not visible on mobile was created by amandat
Posted 8 years 8 months ago #17779
Hello, my Main Menu is sitting in the "Menu" Module but does not appear on my mobile phone, (i can see the menu on my desktop and laptop). I also have a widget with text sliding in which also does not appear on my mobile.
[secret]website is ajonline.net.au (username: joomplates | password: joom1plate)[/secret]
thank you!
Amanda.
Last Edit:8 years 8 months ago by amandat
Last edit: 8 years 8 months ago by joomlaplates.
Replied by joomlaplates on topic Menu Module and Widget not visible on mobile
Posted 8 years 8 months ago #17780
Hi Amanda,
password/user doea not match.
By the way, please read these instructions to add a mobile menu.
www.joomlaplates.com/support/documentati...etup-the-mobile-menu
Replied by amandat on topic Menu Module and Widget not visible on mobile
Posted 8 years 8 months ago #17782
thank you and apologies!
[secret]Username: joomlaplates
password: joomlaplates[/secret]
i have an offcanvas menu although i can't seem to get it to work for the widget i created. does it work for widgets?
also the Widgetkit "slideshow settings show a number of effects available. some do not seem to work. is this because the widgetkit "Free" download only supports Slideshow (lite)?
Thank you.
Amanda.
Last edit: 8 years 8 months ago by amandat.
Posted 8 years 8 months ago #17783
Hi Amanda,
I can see the offcanvas menu link, see image attached.
If you publish a mobile logo, then the menubar have more space.
Warp 7 Templates provides the logo-small position, where you can display an alternative logo image for smaller viewport sizes.
Attachment mobile-2-3-4-5-6-7.jpg not found
The widgetkit lite has not effect limitations.
Maybe you get a conflict with other slideshow ( bt slider) maybe thats the reason why some effects are not working.
Posted 8 years 8 months ago #17787
Hello again,
after stripping back everything that could be conflicting with the slider effects, i ended up reinstalling the widget.. I think i found what the problem was. It appears that the effects were hard to see because i had the same pictures loading in the widget. Once i changed the pictures for three different ones you are able to see the effects clearly. Thanks for your help!
by amandat
