custom module layout style
I made a custom module and published it by inserting [module-369] in my blog article because the positions available don't work for me in this case. To apply a style I still used a position in the module settings (without assigning it anywhere). I went to Extensions/Templates/Styles/ jp-sounds-default/Modules to choose the style "Shadow" but it seems only to apply when the module is not assigned to a page and has it's position.
How can I get the shadow style for my module when it is not assigned but inserted via [module-369]?
Thanks
Thomas
Thanks
Thomas
by rast537
please check which style is loading in the >> plugins > load modules
Try some different styles likes DIV or any other style.
Attachment Screenshot_6-2-3-4-5-6-7-8-9-10.jpg not found
Optionally can specify module style and for loadmodule a specific module by title, Syntax: {loadmodule mod_login,module title,style}.
it didn't work but I found another solution for my quote box problem: the roksprocket quote module. That will do it for now.
Thanks for your help
Thomas
Thomas
by rast537
