Problem changing styles in same website
- EcoComputer
Problem changing styles in same website was created by EcoComputer
Posted 6 years 5 months ago #20875
I create two different styles with the customizer. One with red colors and another one with blue colors.
Im using the "red" style by default and i want to use the "blue" style with one section of the web. For doing so i duplicated the "red" one and changed the colors, then i selected the menu items i want to show that template. The problem is that when i change the style in one template it also changes in the other one so i cant use them separately. What im doing wrong?
I hope i explained it correctly. Sorry for my english.
Regards.
Regards.
by EcoComputer
Replied by joomlaplates on topic Problem changing styles in same website
Posted 6 years 5 months ago #20877
if you want to have different styles for different menu item you have to do this with layouts.
YOU cant duplictae the theme!!
Here is an instruction, how it works
www.joomlaplates.com/support/documentation/warp-7-layouts
Last Edit:5 years 10 months ago
Last edit: 5 years 10 months ago by joomlaplates.
- EcoComputer
Replied by EcoComputer on topic Problem changing styles in same website
Posted 6 years 5 months ago #20879
I was a little confused, now it works. Thank you very much!
Regards.
Regards.
by EcoComputer
