[SOLVED] Problem with google analytics code
Problem with google analytics code was created by griffin
Posted 7 years 6 months ago #21468
I use your rooms templates, it works fine. But I hace some problem with google analytics code. If I see with google tag assistant, I see two analytics codes (the same code) installed in my site. Can you hepl me? where did I go wrong?
[secret]The site is www.martinapugno.com/administrator
user: jo_admin
password: griffin1966[/secret]
Thank you!
by griffin
Replied by joomlaplates on topic Problem with google analytics code
Posted 7 years 6 months ago #21470
Ups youre right, its a bug.
Please open the file > layouts/theme.php and delete the line, see image below
<?php echo $this->render('footer'); ?>
Attachment Screenshot_4-2-3-4-5-6-7-8-9-10-11-12-13-14-15-16-17-18-19-20-21-22-23-24-25-26-27-28-29-30-31-32.jpg not found
The following user(s) said Thank You: griffin
Replied by griffin on topic [SOLVED] Problem with google analytics code
Posted 7 years 6 months ago #21475
by griffin
