[SOLVED] Side not responsive on my phone
I testing this joomla template but on my phone(S7) the template is not responsive. What do I need to change?
Last Edit:6 years 3 weeks ago
by mvw71
Last edit: 6 years 3 weeks ago by mvw71.
I can't discover anything wrong.
Could you explain what you expect?
Greetings,
Christian
Greetings,
Christian
by cg
Here is the Url.
www.zephyros.nu/
I expect that the sidebar on a mobile device is gone and a menu appear on the left side of the logo. If I look at the desktop and make the browse smaller it works but on a mobile device I still see the normal webside.
www.zephyros.nu/
by mvw71
your site is loading within an iframe and not via DNS.
Please check your Provider settings and redirect your Url to the right direction.
Because the org site ( folder) is working correctly
www.zephyros.nu/dir/index.php
The following user(s) said Thank You: mvw71
Replied by mvw71 on topic [SOLVED] Side not responsive on my phone
Posted 6 years 3 weeks ago #22004
by mvw71
