[SOLVED] Module Top-a icon in ICE template
when editing one of the modules in the top-a position there an Icon and on the editing panel i can manage to add an icon to a normal normal module in the same position but not the home position also the sise and so on is not the same, i've been looking everywhere but couldn't find anything, a little help please.
by nordin
Replied by joomlaplates on topic Module Top-a icon in ICE template
Posted 7 years 3 months ago #22324
please make sure you have disbaled the Tiny Editor when you insert the icon code.
www.joomlaplates.com/support/documentati...content-was-cleansed
i tired all the possible soluciton and it never works, the only thing that really solve was to install a different editor, thanks a lot for the help
by nordin
Replied by nordin on topic [SOLVED] Module Top-a icon in ICE template
Posted 7 years 3 months ago #22328
by nordin
