need help with a Home Top A slide show error msg
  • jzakrie
  • jzakrie's Avatar Offline Topic Author
need help with a Home Top A slide show error msg was created by jzakrie
Posted 5 years 10 months ago #22443
I had a Home Top A Slideshow working fine and then I mad a change in the advanced options (shich now after numerous attempts to fix, I don't even originally remember what I did) but I'm now getting "" The parameter "roksprocket.layouts..service" must be defined. ""
The slideshow is no longer showing... any help?
Website - theevilnecessity.com
by jzakrie
Replied by joomlaplates on topic need help with a Home Top A slide show error msg
Posted 5 years 10 months ago #22444
any roksprocket module, which is published has an error and provider selected.
You have to disable all rospracket modul and enable them step by step to find the error modul.
After that delete this modul and create a new one.
The following user(s) said Thank You: jzakrie
