Headerbar Slideshow does not work
Headerbar Slideshow does not work was created by schalloutdoor
Posted 5 years 10 months ago #22575
when working with BIstro template headerbar a with slideshow only works in first installation.
As soon as i open Modul and try to edit text, both images will be shown one below the other.
Text Bistro and Amazing is shown between both images and links, buttons and slide do not work.
Just to check I installed a new test page. Same mistake occured when only opening module in editor and close it again without editing.
Screenshot attached.
Everything else is fine with this template.
Last Edit:5 years 10 months ago by schalloutdoor
Last edit: 5 years 10 months ago by schalloutdoor.
Replied by joomlaplates on topic Headerbar Slideshow does not work
Posted 5 years 10 months ago #22579
please use this code for the slideshow
demo.joomlaplates.com/jp_bistro/docs/
And please use NO Editor when you insert the html code otherwise the slideshow will not work
yootheme.com/support/question/67584
