Problem with margin in header
  • griffin
  • griffin's Avatar Offline Topic Author
  • Senior Boarder
  • Senior Boarder
  • Thank you received: 1
Problem with margin in header was created by griffin
Posted 5 years 10 months ago #22605
I tried to change the setting of the right margin of the text in the header, without result. Can you help me?
by griffin
Replied by joomlaplates on topic Problem with margin in header
Posted 5 years 10 months ago #22608
Live Url please!
  • griffin
  • Senior Boarder
  • Senior Boarder
Replied by griffin on topic Problem with margin in header
Posted 5 years 10 months ago #22612
by griffin
  • griffin
  • Senior Boarder
  • Senior Boarder
Posted 5 years 10 months ago #22613
Hi, I send you admin and password, because the website is offline,
thanks!
[secret]
user: jomplates
password: jomplates
[/secret]
Last Edit:5 years 10 months ago by griffin
Last edit: 5 years 10 months ago by joomlaplates.
Posted 5 years 10 months ago #22619
you can setut the inner gap with a padding > Customizer > Advanced > Panel
BTW: YOu are using the a special modul with a special css class ( jmod??), see image attached, therefore you have to edit the css class from this modul maybe.
Attachment panel-2.jpg not found
Last Edit:5 years 10 months ago by joomlaplates
  • griffin
  • Senior Boarder
  • Senior Boarder
Posted 5 years 10 months ago #22620
the module is a normal header module. I try to change something with customizer> advanced> panel but without results.
I don't know... If I work with css file for header module?
(thanks!)
by griffin
